06-09-2020 10:19 AM
Hello.I bought two P4618 for my server HPE DL 360 Gen10.Recently i used p4600 and p3700 (have per two).For example in p3700 800GB pci ssd in disk management i see 2 pci ssd drive work as one(if one of ssd dead second will work as active passive or raid1).Know i installed p4618 and see 4 logical drives per 3.2 tb.How can i use 6.4 with raid 1?(i have two p4618)
06-11-2020 07:02 PM
Hello, RMamm2.
Thank you very much for waiting.
I have confirmed that setting up different RAID configurations between parts of the SSD or between SSDs should be possible.
For example, it should be possible to:
- Create a RAID 1 between one half of drive #1 and one half of drive #2.
- Create a RAID 10 between the four 3.2TB parts to have a 6.4TB RAID 10.
If there is anything else, please let me know.
Best Regards,
Bruce C.
A Contingent Worker at Intel
06-09-2020 10:37 PM
Hello, RMamm2.
Thank you for contacting the Intel® Community Support.
I checked your ticket regarding the Intel® SSD DC P4618 Series, I will be glad to assist you.
Please allow me to confirm some details regarding this drive and I will contact you back as soon as possible.
Bruce C.
06-09-2020 11:01 PM
Hello..Iready to give aall info about two my p4618.
06-09-2020 11:27 PM
I bought 2 physical dc 4618 and install to my dl 360 gen10,now i see 4 logical drive per 3 tb.i need clear 6.4 tb per physical p4618 in disk management for do mirroring between two physcial p4618,now i cannot because i have 4 logical drive per 3tb.i cannot insall rst drivers for my server because drivers not support windows server 2019 that i use.I use p4600 and p3700 in diffrent servers and havent issue like that.Please help me.
06-10-2020 08:02 PM
Hello, RMamm2.
Thank you very much for all the details.
After reviewing the SSD specifications, I can confirm that this drive was designed with 2 drives and 2 controllers inside. This means that each controller manages half of the SSD; causing this drive to show up as 2 separate drives.
This allows you to configure the SSD in RAID-0 to reach the whole capacity (combining both sides) or RAID-1 to show one 3.2TB drive (one half mirroring the other).
Let me know if you have any other questions or concerns.
Bruce C.
