downgrade firmware from 8DV101F0 to 8DV10171
01-06-2017 03:20 AM
We are currently using Intel SSD SSDPE2MD400G4 (intel-nvme) P3700 for vmware vsan 6.0 U2 p4.
About two weeks ago, we are having problem with the nvme so that vmware support ask us to upgrade the firmware to the latest.
At the time of delivery, the nvme used 8DV10171
Now, nvme use 8DV101F0
Unfortunately, after we check the latest firmware have not certified by vmware (we are using vmware vsan.
The support ask us (again) to downgrade the firmware to 8DV10171
Is there any workaround for downgrade the firmware ?
we have try several tools but is does not work.
Tools said that we already using the latest firmware.
Any help appreciated.
Thanks.
01-06-2017 02:43 PM
Hello Gari,
We understand you would like to downgrade the firmware on your SSD, let us tell you this is not possible as we cannot downgrade the firmware.
We do always recommend to have our drives in the latest firmware version; however, we know that VMware* validates or certifies some firmware depending on each SSD model, so what we can suggest is to contact VMware* and work with them to get this latest firmware added to their systems so it can be certified.
Any other question please let us know.
Regards,
NC- Mark as New
01-08-2017 11:22 PM
Hi NC,
Per today, firmware already listed in the VCG.
http://www.vmware.com/resources/compatibility/detail.php?deviceCategory=ssd&productid=40169&deviceCa... http://www.vmware.com/resources/compatibility/detail.php?deviceCategory=ssd&productid=40169&deviceCa...
Which side (VMware or Intel) who capable to make sure the driver is right and compatible ?
I think the driver is the same with 8DV10171
01-09-2017 02:09 PM
Hello Gari,
We only provide the drivers from our download center site, but as you can notice, it does not include drivers for VMware*.VMware* has the drivers for NVMe devices to support their environments, https://my.vmware.com/web/vmware/details?productId=491&downloadGroup=DT-ESX55-INTEL-INTEL-NVME-10E11 here is the latest driver according to their website. Basically, VMware* is in charge of providing the driver and the compatibility with any NVMe* drive.Regards,NC- Mark as New
01-17-2017 05:52 AM
Hi Gari,
We are following up and we would like to know if you have any questions or need further assistance.We will be waiting for your response.Regards,NC
