Options
09-23-2016 05:35 AM
What is the difference between these two model numbers of 6000p m2 ssd drives?
1 ACCEPTED SOLUTION
Options
09-23-2016 09:23 AM
1kilo,
That's a very good question! Thanks for asking. We are sure many other users will find it very helpful. The difference between one and the other is the following:- SSDPEKKF256G7X1 indicates that the Intel® SSD Pro 6000p Series (256GB, M.2 80mm PCIe 3.0 x4, 3D1, TLC) is a reseller single pack as you can confirm it here: http://ark.intel.com/products/94907/Intel-SSD-Pro-6000p-Series-256GB-M_2-80mm-PCIe-3_0-x4-3D1-TLC# @ordering ark.intel.com -Intel® SSD Pro 6000p Series
- SSDPEKKF256G7ES - Indicates that this drive is an Engineering Sample and it is NOT meant to be sold to end-users.
1 REPLY 1
Options
09-23-2016 09:23 AM
1kilo,
