DC S3520 SSD Power Loss Protection Failure (RAW value)
06-23-2018 10:45 PM
I was checking the Intel SSD Toolbox and noticed the AFh ID had significantly increased. Is a Power Loss Protection Failure RAW value of 13 digits (1760942046368) and increasing - normal for a drive with only 312 Power-On Hours? All the normalized values are good, and I've read the pdfs pertaining to 'last test result', 'total tests', and 'time since last test', but can't find any information of what a normal RAW range should be.
i.e.
Bytes 0-1: Last test result as microseconds to discharge cap (15550)
Bytes 2-3: Minutes since last test (83)
Bytes 4-5: Lifetime number of tests (410)
The product specification pdfs show this RAW value as a hex but it doesn't match the decimal equivalent of the 3 byte ranges above. I'm wondering if my PSU is bad or is this a normal range for a fairly new S3520?
06-25-2018 07:19 AM
Hi ZER999,
After checking the 13 digits value that you provided, I'd say that everything is normal and your SSD is working fine, especially if you are saying that all other values from the SMART report are good.As you mention, the Power Loss Protection Failure should be divided in 6 bytes and read as follow:- Bytes 0-1: Last test result as microseconds to discharge cap.
- Bytes 2-3: Minutes since last test.
- Bytes 4-5: Lifetime number of tests.
