02-12-2019 02:13 PM
Hi, i have buy SSDSC2KG960G701 version J52603-002 but it's not detect in idrac9 on DELL R730xd (controller HBA330). The disk work in guest OS but not detected in Idrac8.
I have ask to DELL support , they tell to contact Intel support....
EDIT : Not idrac9 but idrac8
02-14-2019 08:52 PM
02-12-2019 11:29 PM
02-13-2019 06:39 AM
Hi Josh,
Thank you for your answer. I had try it but my GuestOS is Vmware vsphere ESX 6.5 and i can't execute bash script to give you the SSU log or SMART Logs.
Can you tell me how i can give you some informations that you need to help me please ?
Best regards.
02-13-2019 06:46 AM
I have extract this log list device. This help you ?
It's Model: INTEL SSDSC2KG96 that is not detect in Idrac8.
The controller disk is :
Dell HBA330 Mini
ControllerFirmwareVersion 13.17.03.00
The idrac8:
FirmwareVersion 2.52.52.52
02-13-2019 11:47 PM
