03-28-2015 01:01 AM
I am trying to enable eDrive to use with bitlocker. It is telling me that the firmware is not up to date.
C:\Intel_SSD_Pro_Administrator_Tool_win64>SSDProAdminTool_1.1.0_win64.exe -drive_index 0 -enable_edrive
| Drive Index: | 0 |
| Drive Series: | Intel SSD Pro 2500 Series Opal Ready |
| Model Number: | INTEL SSDSC2BF180A5L |
| Serial Number: | |
| Firmware: | LTVi |
| Current MAX LBA: | 0x14F5C82F |
| Drive Status: | Healthy |
| Opal State: | Opal Ready |
| eDrive Supported: | False |
| Native MAX LBA: | 0x14F5C82F |
| Current Percent: | 100.00 |
| Current Capacity: | 180.05 GB |
| SMART: | ON |
| DIPM: | ON |
| Write Cache: | ON |
Error: enabling eDrive with this tool is not supported on the selected Intel
SSD. Please ensure the tool and the drive's firmware are up to date.
06-12-2015 01:03 PM
Here is my Output:
| Drive Index: | 0 |------------------------------------------------------------| Drive Series: | Intel SSD Pro 2500 Series Opal Ready || Model Number: | INTEL SSDSC2BF180A5L || Serial Number: | CVTS45220AZJ18**** || Firmware: | LTVi || Current MAX LBA: | 0x14F5C82F || Drive Status: | Healthy || Opal State: | Opal Ready || eDrive Supported: | False || Native MAX LBA: | 0x14F5C82F || Current Percent: | 100.00 || Current Capacity: | 180.05 GB || SMART: | ON || DIPM: | ON || Write Cache: | ON |------------------------------------------------------------Error: enabling eDrive with this tool is not supported on the selected Intel
SSD. Please ensure the tool and the drive's firmware are up to date.06-12-2015 03:19 PM
We will need to get some additional details to confirm the reason for this condition.
Please check your private messages for further instructions.
06-12-2015 03:22 PM
PM Sent
I have tried to run a diskpart - clean procedure on the drive and am still not able to enable eDrive using a separate machine with the drive attached as a guest drive. at this point I suspect it's something to do with the firmware. The firmware update tool shows that the drive is already running the latest version.
07-17-2015 08:51 AM
Have you been able to resolve this issue? I'm trying to do the same on a Lenovo T450 with an intel Pro 2500 drive.
07-17-2015 12:57 PM
Hello PolishPaul,
If the drive was bought from Lenovo as part of the laptop, we advise you to contact http://support.lenovo.com/us/en/ Lenovo Support to obtain eDrive management tools.
We do not have the details of your SSD, however, if the firmware of the SSD is LTVi like the one from the previous drives in this thread, then this is a Lenovo drive.
OEM's like Lenovo incorporate customizations to their hardware and firmware, and you should contact them to enable security features like eDrive.
The Intel® SSD Pro Administrator Tool does not support enabling eDrive with OEM drives.
