06-14-2019 07:56 PM
I have installed the above drive but getting really slow speeds compared to the original SSD. The instructions to ugrade firmware fro Majave don't work as disk utility will not load the iso.
What else can I do to get the expected speeds?
06-14-2019 08:44 PM
06-14-2019 08:44 PM
You should contact apple support for help with your mac.
Doc
06-14-2019 11:46 PM
Turns out it is showing as having a lane width of 1 on my MacBook instead of x4. I am returning.
