600p 128gb issues
IKerr
I am currently having troubles getting a new 600p 128gb m.2 drive to be recognized by my BIOS. I have 2 drives which i was planning on setting up as raid drive and using it as boot drive for windows. The BIOS initially saw and the RAID set up just fine. I tried to install windows onto the drive from a USB but i had issues getting the RST drivers to install. After a few restarts and failed attempts one of the drives has just disappeared from the system and the raid is showing up as failed in the bios with only the one drive now recognised. I have tried switching the 2 drives between both the m.2 ports on the mobo and it doesn't appear to be an issue with the ports as the second drive works fine in both. I am not sure if its a faulty drive or there is something else i can try to fix it.
The mobo is a new ASUS ROG maximus 9 code with the latest firmware installed on it and a core i5 7600k.
Iain Kerr
1 ACCEPTED SOLUTION
Hello Iain.Kerr,
We understand one of your SSDs is no longer recognized, after trying to setup a RAID configuration. Based on the situation and your troubleshooting steps, it seems one of the drives may be faulty, but, could you please confirm the following:-Is the drive not detected at all if you only plug that one?Since this could be a possible RMA, you can either contact the place of purchase or our http://www.intel.com/content/www/us/en/support/contact-support.html support department.Regards,Nestor C
6 REPLIES 6
IKerr
Hi Nestor
sorry for the slow response. It has been RMA back to the place it was purchased and they are sending a replacement out.
thanks
iain Kerr
Hello Iain.Kerr,
Thanks for confirming that the place of purchase took care of the situation. In case you need further assistance, please do not hesitate to contact us back.Regards,Nestor C
