The driver detected a controller error on \ Device \ HardDisk0 \ DR0.
02-01-2010 04:54 AM
MODEL:INTEL SSDSA2M080G2GC
Serienummer.CVP0952000R7080GNFirmware: 2CV102HDInstall win 7 pro 64 bit on a intel x25-m SSD on asus p5e3 motherboard BIOS:1503
install Intel(R) Chipset Software Installation Utility V9.1.1.1019intel matrix storage controller v.8.9.0.1023 (from asus site)install Marvell 6121 SATA Driver V1.2.0.69 for 32/64bit Windows7.(from asus site)when i try to install from DVD drive or try to copy from other HD (intern or usb) the PC freezes periodicallyand in Event Viewer under system I see a dozen errors :The driver detected a controller error on \ Device \ HardDisk0 \ DR0.(sorry it is danish)Lognavn: SystemKilde: DiskDato: 31-01-2010 16:44:40Hændelses-id: 11Opgavekategori:IngenNiveau: FejlNøgleord: KlassiskBruger: I/TComputer: seje-PcBeskrivelse:Driveren detekterede en controllerfejl på \Device\Harddisk0\DR0.Hændelses-Xml:http://schemas.microsoft.com/win/2004/08/events/event"> 11 2 0 0x80000000000000 4726 System seje-Pc \Device\Harddisk0\DR0 0400800001000000000000000B0004C00301000000000000000000000000000000000000000000007A3A000000000000FFFFFFFF07000000580000050000000004200A128C022040006E00003C00000000000A000000000068BA5E0780FAFFFF000000000000000060B75E0780FAFFFF00000000000000002084B704000000002A0004B7842000003700000000000000000000000000000000000000000000000000000000000000and when i start intel matrix storage controller i can see that my SDD i now only generation 1.
after reboot it is back to normal (gen2) and working fine. copy between partitions on the SSD givs no problem.if i start win 7 pro 64 bit on my seagate HD (the other HD) it works fine copy or install to the SSD works fine...any suggestions on what is wrong?- Mark as New
02-04-2010 04:33 AM
NO real pc wizards here... Fernando.. maybe
hmm here are some more:
Install win 7 pro 64 bit on a intel x25-m 80gb gen2 SSD(Firmware: 2CV102HD)
on my asus p5e3 motherboard(bios 1503)with intel_msm_8.9.4.1004-full(http://www.station-drivers.com www.station-drivers.com) drivers (the 64bit loaded under the installation) install INF Update Utility Ver:9.1.1.1025 then msm_8.9.4.1004 and its working fine.install a couple of games and its runing nice ( 264Mb/s read in crystaldiskmark2.2) then...I plug in my net cable and Windows prompt me to select the type of Networkonce i select Home Network, (Windows 7 will start applying the necessary settings for my new network) i register windows 7 no problem but after ca 10 min...
i got a dozen errors in Event Viewer under system:The driver detected a controller error on \ Device \ HardDisk0 \ DR0.and the PC freezes periodically....(with every "freeze" a new error) dont have to do any thing on it...In Matrix Storage Manager im back to generation 1...still same drivers under my controller ( and now 84 Mb/s read in crystaldiskmark2.2)after reboot im back to generation 2 in Matrix Storage Manager,but just for 10 min or so then same problem.... any idea what wrong? thanks in advance- Mark as New
02-04-2010 01:25 PM
I had the same error. I think it is due to a chipset bug or bad drivers. Let me explain:
I have Windows 7 64 bits on ASUS P5B-VM motherboard that has ICH8 with 4 SATA ports and one JMicron JMB363 controller with 2 SATA ports.
http://asus.com/product.aspx?P_ID=hVGq6LftD7U3PRkX
I had X25-M G2 80GB connected to SATA1 and Seagate ST3500418AS connected to SATA2 (both on ICH8) all with Microsoft drivers. This worked without any problem for a month.Then, one day I connected another Seagate ST3500320AS to SATA3 (next free port of ICH8) and I started to get freezes and "controller error on \ Device \ HardDisk0 \ DR0".
Only solution that worked for me: I removed Seagate ST3500320AS from port of ICH8 and connected it to JMicron JMB363 controller.
No one single error from that day!
HTH!
02-06-2010 04:59 AM
Made a clean install with the drivers from http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Chipsets&ProductLine=Chipse... Here
same problem BUT!!!found that is is when ill disable my netcard the problems starts.....
dont no why but win 7 dont like that.....
does anyone know how to go around this?
cos i only want to have this as a gambling pc with no antivirus and all of this (lack of preformence 🙂 )
in regards
Kenn
