SSDSA2CW080G310 and SSDSA2CW080G3K5 difference
I see basic two models for Intel SSD 320 series 80GB.
  • SSDSA2CW080G310
  • SSDSA2CW080G3K5
What are the differences between them? I would appreciate some feedback.
4 REPLIES 4
I may be mistaken, but the 3K5 version comes with the 2.5" to 3.5" tray and sata cable. The 310 version is just the SSD. Other than that they are the same.
The SSD themselves are identical. The last two alphanumeric characters just represent ordering/packaging information.
Relic is right,
If you don't need the cable or bay adapter then get the ...10 version, the ...K5 is usually about 10.00$ more for the extra stuff.
what about the warranty period? does it carry the same warranty like b5 and k5??
