SSD 80 or 120GB
I would like to buy SSD 320 for Windows 7 professional. What capacity do you recommend? I will make separate partition for my documents but programs will be on the same one as system. The additional assumption is that I would like to use Windows XP Mode and Windows Virtual PC. What capacity would be sufficient for SSD 80 or 120GB?
Thank for your feedback.
3 REPLIES 3
Yup, his numbers are great estimates.
How much space are just your programs using today?
My programs are using about 10GB.
depending on the size in wich your programs would use than you may have to go to 120gb but if you set it to a dynamically expanding disk than it will grow when you need more space thus making it easyer to install what you need.
