12-01-2009 04:24 PM
I think my sequential read speed (on X25-M G2 80GB) is low, it's 134 MB/s,
shouldn't it be above 200 ?
I measured it before and after the new firmware update, it's the same.
I'm running Win7 32bit (for few months now, not a fresh installation)
12-01-2009 05:11 PM
Is your SATA port 3.0GB/s or 1.5GB/s? if it is 1.5gb/s, I think there is a limit on the port
12-01-2009 06:22 PM
i think PCI is limited to 133MB/s... so i don't think you can get more out of your drive
12-02-2009 03:49 AM
My MB supports PCI 2.2, so it supports both 33Mhz and 66Mhz PCI, the limit for 33Mhz is 133MB/s and if you use 66Mhz I believe it should be double than that
