Safely Remove Hardware?
01-10-2010 09:49 AM
I recently got myself a G2 160GB and installed W7 Pro 64-bit. During the install, the SATA controller was set to IDE, and reading that TRIM was only auto-active using AHCI, I followed this guide: http://support.microsoft.com/kb/922976 http://support.microsoft.com/kb/922976 and went into the BIOS, changing it to AHCI. I also updated to the latest firmware after doing this. However, now the SSD shows up in Safely Remove Hardware and Eject Media, and is a constant icon in the system tray. Why is this, and how do I stop it?
01-13-2010 07:04 AM
http://www.station-drivers.com/page/intel%20raid.htm http://www.station-drivers.com/page/intel%20raid.htm
It appears if you use 'ICH10R', you need the older one I used.
01-13-2010 08:21 AM
Does RST support auto-trim? As in does it TRIM when W7 tells it to?
01-13-2010 08:35 AM
No, not yet anyway.
01-13-2010 08:38 AM
I can live with the little icon if I have my auto-trim.
01-13-2010 08:52 AM
As long as you don't click on the eject button of the SSD with the running OS on it, there is no problem whatsoever
