Is AS SSD tool stats accurate for hard drives?
This question is not Intel specific but I am asking it here because I know a few users here use AS SSD for benchmarking. I used the tool on a couple of hard drives and got scores of 12 & 15. Very low. Are stats from AS SSD accurate for hard drives or is the tool specifically made for SSD's and hard drives do not apply.
I am trying to benchmark an SSD and a hard drive on an equal level. Is there a benchmark tool which works for both types of storage acurately?
3 REPLIES 3
One more thing. .. the partition aligmenment figures for the hard drives say BAD in red. Is this normal? This also happened once for the SSD while i was creating partitions and restoring an image.
How do I fix the alignment to say OK? I don't know much about the alignment stuff.
Gogle ( ATTO Benchmark ) It's free and one of the most accurate programs out there and you can use it on SSD or Reg HDs also.
As far as the partition alignment ( Paragon Software sell a program for Alignment ) You can use to check part. align after OS is installed without fear of loosing anything.
