IntelBootLoader - 8.4 GB
Hi , I have some issues with my ssd Intel Postville.
At the begining he was correctly detected as SSDSA2M080G2 and 80Go of size. It was also working with as OS on it.
But since tonight he is detected as : IntelBootLoader - 8.4 GB in the bios. and we can't boot on it.
Someone havethe same issue? how can I solve the issue?
Cheers.
Jonathan
7 REPLIES 7
RMA is the only solution, unfortunately.
Why? Is it a konw issue?
Thanks for having replied fast.
Have you tried a secure erase, its worth a try. <!--[if gte mso 9]> Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--><!--[if gte mso 9]> <w:Lsd...
I don't understand the link betwin the software that erase the data and my issue. Moreover this soft should recognize only 8.4G of my ssd.
