Intel® X25-M Firmware Update Error
12-01-2009 04:54 PM
Hi all, i've downloaded the new firmware and am having a weird error when running the firmware. I boot into dos and the disc detects my SSD drive fine but during the update when you see the _ blinking, it will pop up with an error saying. Error reading from drive A: Dos area : General Failure Abort ignore retry fail
Retrying does the same thing, so i dont know what's going on. In my bio's it's set at compatible and IDE, am i suppose to set this to ACHI?
Anyone else have this issue and if you fixed it, can you explain how?
12-01-2009 06:26 PM
Here is the exact passage from the ReadMe (it is such a long readme that is is certaintly easy to miss):
BIOS STORAGE CONFIGURATIONThis tool will only function correctly with the BIOS SATA ports configured to "Legacy" / "Compatibility" mode, or "AHCI" mode. Some BIOS configurations support SATA port modes such as "IRRT", "RAID", and "Native + IDE" mode, which are not supported by this utility.- Mark as New
12-01-2009 06:54 PM
Update error too for me : on my Vaio AW laptop i've got an "Intel SSD not found" message. I know that i should try to set my SATA mode from AHCI to IDE, but my BIOS only gives access to time, date and drives boot order settings.
Mailed support, hopping a less restrictive updated tool
12-01-2009 08:01 PM
I have the same problem.
It says "Intel SSD is not properly attached or disabled"
I have a Gigabyte GA-MA770T-UD3P motherboard with the latest BIOS.
My BIOS SATA port mode was set both to IDE and to AHCI SATA without any success.
Why is this happening, and what can I do?
I have an Intel X25-M G2 80GB SSD.
12-01-2009 08:10 PM
You tried it both ways? If you did, try Legacy or Compatibility mode.
12-01-2009 08:24 PM
In my BIOS, under Integrated Peripherals, I have:
-OnChip SATA Type:
*AHCI
*RAID
*Native IDE
-OnChip SATA Port 4/5 Type :
*As SATA type
*IDE
How should I set those?
I have tried AHCI and Native IDE so far.
I don't see anything like "Legacy or Compatibility mode" in my BIOS
Can you help me please?
