12-01-2009 04:54 PM
Hi all, i've downloaded the new firmware and am having a weird error when running the firmware. I boot into dos and the disc detects my SSD drive fine but during the update when you see the _ blinking, it will pop up with an error saying. Error reading from drive A: Dos area : General Failure Abort ignore retry fail
Retrying does the same thing, so i dont know what's going on. In my bio's it's set at compatible and IDE, am i suppose to set this to ACHI?
Anyone else have this issue and if you fixed it, can you explain how?
12-01-2009 05:37 PM
The ReadMe explicitly states to set SATA to ACHI and not to RAID or IDE when doing the firmware update. Then afterwards you can set it back to what you like.
Regards,
Mike
12-01-2009 05:43 PM
thanks, i appreciate the reply
will try later, i read the guide and it doesnt state anything like that
cheers
12-01-2009 05:57 PM
The readme also states:
"2. "Drive not recognized" in AHCI SATA modeISSUE: Some platform BIOS implementations of SATA port settings are not compatible with the update program's process for locating the SSD within the system in AHCI mode.WORKAROUND: For best compatibility, configure the BIOS SATA port mode to The "Legacy" or "Compatibility" mode to perform the firmware upgrade"The above is only if you have an issue using AHCI mode.12-01-2009 06:11 PM
thanks for that, well it's definately not working for me in IDE mode, so i hope it works in ACHI
really dont want to go to a friends house just to do this firmware update
