Intel 510 elm crest 120gb SSD Help...
05-13-2011 08:36 PM
i got a question the reason i change in my efi bios to ahci rather ide was because i seen a major increase in read/write speeds...now let say if i get another ssd to make it much faster and majorly more space should i raid it?? and if i do then how will this effect my hhd's i have and my dvdrwr i have on the sata ports??? please any help would be great,...thanks...this is my setup just incase you guys want to see my built:::: http://youtu.be/PJA9YDKE8Hc http://youtu.be/PJA9YDKE8Hc
05-16-2011 11:25 AM
im using the intel rapid storage technology 10.1.0.1008 for sata...
im using windows 7 home premuim...
its plugged into the 6gbps sata port on my asus motherboard...http://www.asus.com/Motherboards/Intel_Socket_1155/P8H67M_PRO/ http://www.asus.com/Motherboards/Intel_Socket_1155/P8H67M_PRO/
is this good??
can you specify the run to 0 proceedure please...cmd or regedit??
05-18-2011 12:13 AM
You need to run "fsutil behavior query disabledeletenotify" from within cmd.exe (and be sure to run cmd.exe as Administrator).
05-18-2011 12:43 AM
"fsutil behavior query disabledeletenotify" only tells you that the TRIM command is being sent by the OS. It does not necessarily mean it is being executed by the SSD.
05-18-2011 04:08 AM
i typed in that and it now indicates that " disabledeletenotify =0"
im not sure what this means?
05-18-2011 04:13 AM
I means the OS is sending the trim command to the SSD. It does not mean that the SSD is executing that command.
