/Trist
123 REPLIES 123
plee21
New Contributor III
New Contributor III
Hi
To move the drive to another PC remove the password in the original PC first.
You don't have to do a secure erase unless you are giving the drive away, just delete the partitions and start again, in theory running the Intel Optimise function permanently destroys old data. To do a secure erase requires you to hot plug the SSD into the computer after it has booted so that isn't locked to low level security commands. To do this connect the power cable to the drive but disconnect the SATA cable, then reboot, once the system has booted connect the SATA drive cable. I'm not sure if you can do this via USB.
Regards
Phil
JHick3
Can someone from Intel please respond to Ryan's comment above:
If Ryan is correct and the 320 doesn't use KDF for the second AES key, the information provided by Intel is wrong. If the AES key is not encrypted by the ATA password than the 320's FDE implementation is broken and the hashing argument is irrelevant. A comment from Intel would be appreciated.
Technical specifications for any device like this should be public and I encourage everyone to demand them. I've read every comment on this thread numerous times and only one conclusion can be drawn from it: Intel currently implements black box security in the 320 series SSD.
plee21
New Contributor III
New Contributor III
Hi
The whole encryption thing with Intel SSDs seems to be more marketing than anything. In their literature they fail to point out that for encryption to be any good, you need to set a password first, and not all systems will support that. Intel don't seem to engage in any discussions regarding how we can secure our data using their SSDs. It's an additional worry that the even adding a password might still mean we have weak security anyway.
Currently I'm waiting for an Intel response on the fact some of their own brand new motherboards have broken support for setting the password, so at best you can't set one, at worse your PC might not boot up again!
Here is hoping for some information.
Regards
Phil
Anyone know if the 330 series also supports AES? I'm getting mixed information from Intel Tech Support. They claim only the 320 series and 520 support AES? This post also has a broken link that I can't use to confirm:
