/Trist
123 REPLIES 123
vt5
New Contributor III
New Contributor III
Hi SSDelightful, you mentioned about if HDD password, it will lock the drive and cannot recovery, so can we claim warranty replacement from Intel?
[quote]I have Asrock Z68 Extreme4 and cannot boot if password protected intel SSD is connected to any of the SATA ports of the chipset ATA controller. The board locks in endless boot loop. I have to hotplug the drive to make the whole thing work. If the drive is password unlocked or security disabled motherboard boots without any problem.
UEFI in Asrock's case do not work with password protected drives!
Will try Asus P8Z68 Pro next week.[/quote]
Pit you never posted your results from the Asus P8Z68 PRO. Were you able to use the Intel SSD drive with that board? Asrock is a subsidiary of Asus so I'm thinking no but I'm curious. I also have that board and I am considering purchasing an Intel 320 SSD once my questions are answered.
thanks for all the information given here - but I'm hanging at some question:
If I've installed my OS on a 320 without HDD-Pass all data is encrypted, ok. Now I want to enable a password. Is it possible to enable the HDD-Pass in this situation without loosing all data? afaik I'm not able to CHANGE the HDD-Pass later on, but can i SET it without loosing data?
If I want to CHANGE it later on, in my understanding I've to do a full backup, secure erase the device and set a new pass, am I right?
I imagine, the same is true if I want to DISABLE the pass?
What happens, if I enable the pass and start hanging in a reboot loop as somenone wrote here? Same answers as the two questions above?
I read about the different kind (master, user or so) kinds of passes. In my Bios there's onle one pass per HDD. Does this have any security impact?
How does the process of secure erasing and deleting the existing HDD-Pass (I don't mean the aes-keys, I've understood this process) work (aim: getting a "factory state" ssd without hdd-pass)? Giving the right pass in the bios, booting from a different drive, doing secure erase with intel ssd toolbox? What is the thing with disconnecting and connecting the drive (secure lock?), is this needed? How can I enable/disable the "secure erase lock" (my words)?
Very specfic question: Does anyone now if HDD-pass works fine with a dell T3500 workstation (Intel ICH10R, possibility to set HDD-Pass in bios exists for every drive)?
I'm really happy for any hint!
Thanks,
marte
This is my first Post on the mailing list. My name is Jean-Michel Pouré and I am the director of GOOZE, a security company offering smartcards and security tokens.
For our work, we need to secure store some valuable information on servers disconnected from the network. Presently, we are using GNU/Linux with lvm encryption. I bought an Intel 320 SSD with 40 GB of RAM to do some testing under Windows 7 (a system we have nearly 0% trust into) and try to find a solution for customers.
I think we could easily defeat Intel 320 SSD AES encruption, here is how:
1) Our motherboards are ASUS. The system is Windows7. We installed ASUS Flash update, which is a Windows program.
2) We set up user and admin password in BIOS. The only way to boot and/or access BIOS is to enter a password.
So far, so good, is your system protected? No, here is how:
3) We booted into recovery and flashed the BIOS using ASUS Flash update, with option "reset BIOS to default". You could also buy an ASUS motherboard and transfer the SSD (which we did not do). Or remove the battery from the motherboard (which we did not do).
4) After reboot, we could access BIOS without admin password. We simply changed the user password and it installed the new password into the Intel SSD!
5) We rebooted with the newly user created password.
Intel 320 SSD are not secure product, as in most BIOSes the password is not protected by a passphrase.
Under Windows 7, the solution is to use an extra security software level, like using truecrypt with smartcards.
Check this tutorial for example: http://www.gooze.eu/howto/truecrypt-smartcards-and-security-tokens-howto http://www.gooze.eu/howto/truecrypt-smartcards-and-security-tokens-howto
We welcome any information allowing us to secure the SSD completely, even changing motherboards.
We are now testing a more complicated setup:
* Windows system partition encrypted using truecrypt passphrase, from boot.
* Home partitions encrypted using truecrupt and security tokens.
Kind regards,
Jean-Michel Pouré
From your post it seems you only set the BIOS password. This will not set an encryption passphrase in the SSD, you would have to set an ATA password for that.
