03-26-2011 08:14 AM
/Trist
06-18-2011 02:48 AM
Thank you, DesktopMan and Pit. I appreciate the info.
The Intel SSD Toolbox also seems to give a lot of info about the drive. I just ran it and noticed under Word 128, security status information is given about my drive. It lists info on Security Supported, Security Locked, Security Enabled, Security Frozen, Security Count Expired, Enhanced Security Erase Supported, and Master Password Capability.
Pit, I haven't had a chance to run hdparm under linux yet. But, if you have the SSD Toolbox, is this the same info returned by hdparm?
Also, I was wondering if Bit 1 and Bit 2 might be reversed. Should Bit 1 be Security Enabled instead of Security Locked and Bit 2 be Securit Locked instead of Security Enabled? If not, security is not enabled on my SSD because I get a value of 0 for Security Enabled. Can anyone confirm this? Anyone from Intel care to comment on this?
Best regards.
06-18-2011 02:55 AM
I forgot to mention in my previous post that I'm using the Intel SSD Toolbox, Version 2.0.2.000.
Best regards.
06-18-2011 01:14 PM
My 320 is currently in: Maximum Security Mode, unlocked with User Pasword and Frozen.
Toolbox gives me in 128 register: Bit0=1, Bit1=1, Bit2=0, Bit3=1, Bit4=0, Bit5=1, Bit8=1. Interpret it as you like.
A little warning for all you guys using boards with uefi-s.
I have Asrock Z68 Extreme4 and cannot boot if password protected intel SSD is connected to any of the SATA ports of the chipset ATA controller. The board locks in endless boot loop. I have to hotplug the drive to make the whole thing work. If the drive is password unlocked or security disabled motherboard boots without any problem.
UEFI in Asrock's case do not work with password protected drives!
Will try Asus P8Z68 Pro next week.
06-18-2011 05:23 PM
Thanks Pit!
It would be nice to know what the SSD Toolbox settings displayed for Word 128 should be in a properly configured Series 320 SSD. Hope someone from Intel can respond.
Thanks again.
06-20-2011 01:05 PM
Rapid Storage Technology app can give you info about security status in Menage section -> Advanced ->password Protected: Yes/No
