03-26-2011 08:14 AM
/Trist
03-29-2011 01:22 PM
@Atavism
AFAIK there in no technical reason for 8 chars limitation. And you are absolutely right. ATA security specification defines 32-bytes for pasphrase. Well... it seems that unofficial bios modding for adding security ATA extensions will be more common these days. This is the only way I can think of... I've lost any hope that my desktop mobo's manufacturer get rid of the essential flaws in its BIOS anytime soon. Adding security module sounds like sci-fi for me and it is unreal for most of us, unfortunately.
/message/119280# 119280 tristpost asked excellent question about passwords linking. This is the clue.
Intel's documentation suggests that AES keys are generated during Secure Erase procedure. And this is understandable. But the thing is: ATA password seems to be unrelated to AES encryption engine which to be honest reverse the proper implementations upside down. In truecrypt (and many soft-based solutions) for instance password is the first and based on it and random or pseudo-random generator (mouse based in truecrypt) final AES keys are obtained.
Intel's paper suggests that in 320 case AES encryption and SATA pass are separated. You can use AES (well you are forced to, but not complaining) and NOT use ATA-pass at the same time. ATA pass is optional.
These two security mechanisms are not nested. They are not nested!
When you crack ATA password AES becomes obsolete and vice-versa. They are not in logical conjunction.
Impications? Well look at the market. Dozens of manufacturers and theirs ATA pass implementations. And you can crack almost any of them. There are specialized commertial firms witch offer ATA pass removal. And all these security implementation are hardware!! ATA pass is stored in drives firmware or data firmware areas!
The only solution to secure such encryption mechanism I can think of is to encrypt (strong encrypt) generated AES keys with ata pass internally.
Otherwise sooner or later some skilled hacker will find "authorization bit" and this whole sophisticated AES will be absolutely useless.
In my opinion this is not looking like enterprice class security. If I'm wrong, feel free to prove otherwise.
03-28-2011 11:44 AM
Hey tristpost,
Just want to let you know that I'm working on answers for you! Everyone else should look for a 320 post sometime today. Thx!
-Scott, Intel Corporation
03-29-2011 06:14 AM
Bump for information!
03-30-2011 09:05 AM
Looking forward to your "official" answer. Still mostly speculation in the thread....
/Trist
03-30-2011 09:39 AM
another interesting question is (in my opinion) how the Intel 320-series FDE could work together with a new MacBook Pro (early 2011).
Because there's no BIOS - 'only' EFI.
I'm really looking forward to your answer! (hopefully for all questions in the thread)
/Shiek
