03-26-2011 08:14 AM
/Trist
03-27-2011 10:28 AM
I'm not sure but it seems that Intel approach is no differ then SandForce 12xx one. It means: this is ONLY internal encryption with random generated passwords and without user defined passphrese. This solution does NOT increase security against thieves. It speeds secure erasing and add minor layer of security against controller switching (for ATA-pass overriding) and flash memory dumping. Highly rare and uncommon situations these days.
03-28-2011 12:01 AM
Hmmm in that case it is pretty lame - moving a disk between two controllers is even something I WANT TO BE ABLE TO DO.... it is really the data theft issue one want to address (in particular on laptops)....
/Trist
03-28-2011 09:02 AM
The controller switching is rather outdated hack method (mainly for platter drives) based on swapping hdd's electronic board (containing drive's controller and internal bios) to bypass some security methods. It does not concern motherboard controller, the drive's electronics only.
There are IMO much better solutions for securing mass storage these days. Much more flexible then bios-based passwords (with its 8 characters limitation - too small against brute force attacks). All of them are based on preboot authentication (and to be honest they have theirs own issues) but I highly dubt Intel implemented that. We are talking about budget drives.
03-29-2011 10:41 AM
While many bios seem to have 8 character limitations, is there any technical reason for it? As far as the ATA specs go, up to 32 characters should be fine to use.
