horrible results in x25-m...
08-17-2010 07:15 PM
I went through different posts, but cant see a solution.
Just bought a new motherboard and Athlon, put SSD in AHCI mode with Win7. My results:
Sata2, Win7 Home, disabled defrag, superfetch
08-22-2010 03:11 AM
Try turning off all power saving options in the bios and in windows. Your 4k results should then shoot up. I have found that with power saving options like in my case speed step etc on my p55 chipset impacts performance on my intel x25m. Hope this helps.
08-22-2010 08:28 AM
I have found that ATTO gives more real world readings than most. But How many Benchmark programs are there ??
08-22-2010 09:16 AM
Hay James good to see you are still posting , could you post the check list that you referred to ??
08-22-2010 12:07 PM
Robert, I will start working on it. I keep it in my head and have never committed it to paper. This is not a trivial task because expertise and familiarity with specific products can not be assumed. It only uses free and products available with free trials.
When I finish the draft I will email it to you so you can review/test it for me.
08-22-2010 12:50 PM
Thanks I've always respected your advice. use my personal email it's available in my profile .
