09-03-2011 08:45 AM
I Just bought a new Intel 311 series 20GB ssd for my daughters dell mini 9 to replace the original 8GB and the netbook wont power up with it in it can anyone help ??
10-17-2011 01:24 PM
On this specific case I suggest you to try updating the bios of your computer and see if that help, take into consideration that the 311 series of ssds are mSATA form factor, make sure that your system support this type of connection, on any case the recommendation here is to contact the system manufacturer for further assistance.
