Defrag registry?
01-20-2010 06:06 PM
I have an Intel 160Gb SSD. I know that I shouldn't run a defragment on it, but is it OK to defrag the registry?
01-20-2010 09:31 PM
Probably not necessary to defrag the registry - but it is not the same as defragging the hard drive, so if you would feel better about doing it, I don't think it would hurt like doing a file system defrag. The registry files (hives) are pretty small compared to the size of the operating system. Let us know if it speeds things up
01-25-2010 05:58 PM
Does anyone else have an opinion on this topic? Not that I don't trust you Mister IT, I would just like to have a few more opinions.
01-26-2010 02:32 AM
I dont think it would wear the SSD like defraging would, But I dont think you would gain any performance from doing a registry defrag on a SSD.
01-26-2010 08:38 AM
If you are using a specific tool, take a look at the support forums (if one exists) of the tool and ask them
there. Let us know if you find an answer you are satisfied with, as I am sure someone will ask this again.
