08-17-2009 02:58 PM
seems to happen onee a week for 3 weeks now
I break the raid, recreate, and it works fine for multiple reboots for about a week, than i get the error again (see image)
assuming i should just RMA it, its the same drive no matter which backplane, or port i use on ever failure, latest firmware as well.
08-18-2009 06:48 AM
Before RMA it please post your S.M.A.R.T. data
You can use speedfan online service or anything you want (speedfan http://www.almico.com/sfdownload.php http://www.almico.com/sfdownload.phphttp://www.almico.com/speedfan439.exe http://www.almico.com/speedfan439.exe Open SMART tab, select drive and press "perform an in-depth online..." and post link given under "The link to get back and see a new report about this hard disk in the future is http://www.hddstatus.com/hdrepshowreport.php?ReportCode=3920166&ReportVerification=C6D4E975 this." in opened http://www.hddstatus.com/hdrepanalysis.php http://www.hddstatus.com/hdrepanalysis.php ) .
And you can try hdderase v3.3 to erase drive completely (remember to use IDE mode and onboard SATA1 connector, disable other sata controllers in BIOS setup, more information can be found here - http://www.pcper.com/article.php?aid=669&type=expert&pid=6 http://www.pcper.com/article.php?aid=669&type=expert&pid=6), this solved my problems.
Thanks.
Message was edited by: w00thisButtonDo
08-18-2009 01:27 PM
wOOthisButtonDo. I tried that link to almico. When I tried to download it IE tried to block it. When I started the download my AV pops up and tells me it has "TrojanDownloader:Win32/Wintrim.BY" - Threat severe??
08-18-2009 08:11 PM
Ask your AV support why it gives false alarms. Speedfan is not trojan downloader, I am sure.
08-19-2009 12:00 AM
I use MS Essentials and I don't think it was a false alarm. Details of the trojan can be found here: http://www.microsoft.com/security/portal/Threat/Encyclopedia/Entry.aspx?Name=TrojanDownloader:Win32/... http://www.microsoft.com/security/portal/Threat/Encyclopedia/Entry.aspx?Name=TrojanDownloader:Win32/...
"TrojanDownloader:Win32/Wintrim.BY is a component of the greater Win32/Wintrim family that is used for downloading and installing additional http://www.microsoft.com/security/portal/Threat/Encyclopedia/Entry.aspx?Name=Trojan:Win32/Wintrim Win32/Wintrim or http://www.microsoft.com/security/portal/Threat/Encyclopedia/Entry.aspx?Name=Win32/Skintrim Win32/Skintrim components. Win32/Wintrim is a family of trojans that display pop-up advertisements depending on the user's keywords and browsing history. Its variants can also monitor the user's activities, download applications, and send system information back to a remote server."
