Confirm proper Trim? Format or not?
Now that my firmware is completed successfully and my benchmark scores are still fabulous, how do I MAKE SURE that my drive is running as it should? By this I mean with TRIM enabled in Win7 64-bit? What about SMART status?
Also, should I continue using my SSD with my current windows setup (same as stock drive WITHOUT new firmware) or would it be best to format and do a wipe and reinstall everything on the drive now that TRIM is enabled? Would this increase performance? Longevity? Or is not necessary?
1 REPLY 1
CrystalDiskInfo shows TRIM under SUPPORTED FEATURES, but does this mean that TRIM is active????
