Benchmark results of Intel X25-v ssds in RAID 0 ?
07-01-2010 05:59 AM
I have 4 Intel X25-v SSDs(40 G each) configured in RAID 0 with 64K as stripe size. I want to measure the performance of this setup and compare with benchmark results. But I could not find benchmark results of RAID 0 config proposed by Intel. Can anybody point me where I can get the benchmark results of RAID0.
Thank you in advance.
Regards,
Ramu
07-07-2010 02:04 PM
Ramu,
Check out the following site and see if it provides the information you need:
http://download.intel.com/design/flash/nand/value/prodbrf/X25-V_40GB_Performance_Guide.pdf http://download.intel.com/design/flash/nand/value/prodbrf/X25-V_40GB_Performance_Guide.pdf
Regards,
Brady (Intel SSD guy)
07-08-2010 02:25 AM
Any of these 3 test will work for you.
HD Tune:
http://www.hdtune.com/ http://www.hdtune.com/ AS ssd: http://alex-is.de/PHP/fusion/downloads.php?cat_id=4 http://alex-is.de/PHP/fusion/downloads.php?cat_id=4 Crystaldiskmark: http://crystalmark.info/software/CrystalDiskMark/index-e.html http://crystalmark.info/software/Cry...k/index-e.html
