05-17-2010 04:19 AM
05-17-2010 06:41 AM
More than likely there is nothing you can do, apart from hassle ASUS and look for driver/ bios/ firmware updates. Changing the block size will not help. Whilst it is no doubt annoying that your ssd is not working optimally the difference is not something you will really notice outside of a benchmark.
05-17-2010 06:46 AM
thanks redux. i booted in safe mode and ran it again and the 4k went twice as good. 20/50
so it must be a driver thing
at least my ssd is working ok
05-18-2010 02:13 AM
what if the allocation units are offset. could this cause this latency?
if so and in general anyway, how do i completley wipe the ssd + recovery partition in order to set the alignment perfect on a fresh install. last fresh install i did the alignment is a liiiitle off.
thanks
05-24-2010 06:07 PM
Just a quick sanity check:
Intel does not make a 60GB X-25M G2. I assume you meant to type 80GB -- correct?
