12-09-2009 09:38 PM
Hi everyone,
First post here. I just got a new 160gb x25-m g2, successfully flashed the firmware to 02HD, and installed Win7 x64 with AHCI enabled in the BIOS. After getting everything up and running, my WEI disk score is at 5.9. I have the same crystal disk mark scores as other posts, and things "feel" snappy - but I haven't seen others complain of their WEI score. Just curious if others have experienced the same, or if anyone has suggestions?
12-10-2009 11:35 AM
take another wei test while your laptop is on "high performance" power setting !!
12-10-2009 04:37 PM
Prior to making any changes just try rebooting and running the WEI. I have seen on ocassion Win7 will assign a low WEI score the first time it runs after OS install. Rebooting and re-running the index will then produces a higher score. Sometimes more than one reboot and re-run of the WEI is required. With a properly running Intel SSD you should be scoring above 6.5 on the disk score. Most users will be in the 7's
12-10-2009 08:38 PM
Changing the power settings did the trick, I'm at 7.6 now. Thanks!
12-11-2009 10:59 AM
Did you first try re-running the WEI before changing the power settings? Honestely I don't know of anything in the power settings that should affect your WEI disk score. I have a feeling your score came up ONLY because you re-ran the WEI
12-11-2009 03:24 PM
Yep, made no difference. It was definitely the power settings, which is very curious indeed.
And I should note I was on AC power the entire time.
12-12-2009 12:56 AM
My suggestion to change the power setting to high performance was based on me getting the same wei score of 5.9 with my G2 160 02hd firmware, I then remembered that someone over at ocz forums solved a low ATTO benchmark and slow boot by changing the power setting, and that did it for me!
It,s now 7.7 !
