1.8" SSD compatibility
11-11-2010 06:08 PM
Hi folks,
Does anyone know if the Intel 1.8" SSDs (SSDSA1MH160G201) are compatible and fit into HP2540Ps that use the 1.8" inch drive space?
Thanks in advance.
David
11-11-2010 07:49 PM
Not sure.... but it comes in 1.8" hard drive form factor and is 5mm thick. What are the dimensions of the existing drive?
11-12-2010 09:16 AM
I was told by Crucial that their RealSSD C300 CTFDDAA128MAG-1G1 1.8" 128GB SATA III MLC Internal Solid State Drive (SSD) was compatible and the size of it is 78.5 x 54.0 x 5.0 mm and I was told by Kingston that their drive Kingston SSDNow V+ 180 SVP180S2/128G was also compatible and it is 54 x 78.5 x 5 mm
11-12-2010 12:13 PM
Good thing for form factors!
78.5x54x0.5mm
Page 12: http://download.intel.com/design/flash/nand/mainstream/Specification322296.pdf http://download.intel.com/design/flash/nand/mainstream/Specification322296.pdf
11-19-2010 01:08 PM
Yes, that drive fits without problems. I have a HP2530P with that drive. The HP2540P is an evolution of the same laptop.
