10-28-2009 08:25 PM
UPDATE 10-31-09 @3:20p
I=IDE
A=AHCI R=RAIDBRAND NEW
III - GOOD=01 BAD=00 AAA - GOOD=02 BAD=00 AIA - GOOD=02 BAD=00RIR - GOOD=00 BAD=01
INSTALLED (NO REFORMAT/ERASE)
III - GOOD=03 BAD=00 AAA - GOOD=06 BAD=02 AIA - GOOD=05 BAD=04 RAR - GOOD=02 BAD=00 RIR - GOOD=03 BAD=00REFORMAT/ERASE
AAA - GOOD=01 BAD=00 AIA - GOOD=01 BAD=00 IIA - GOOD=01 BAD=00Also reworded some of the questions. PLEASE POST ANSWERS ONLY. Thx
Here' it goes...
10-31-2009 03:55 AM
1-Bios updated to Latest? (YES)
2-What g2 size 80 or 160g? (80G)
3-Is the drive partitioned? (YES)
4-other harddrives installed? (NO)
5-What version of 7, x86, x64? (x64)
6-Was windows 7 Installed already or was it clean? (INSTALLED)
7-Was it aligned before and after update? (BEFORE)
8-Did you reformat or leave windows on before update?(LEFT OS IN PLACE)
9-Was Intel optimizer installed before or after update? (BEFORE)
10-If optimizer was Installed BEFORE the update did you run it? (NO)
11-Bios and windows setting before update? (AHCI)
12-Setting during update? (IDE)
13-Setting after update? (AHCI)
14-Did you run the flasher twice before booting or installing Win7? (1x)
15-Was there an error when flashing? (NO)
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? (YES)
17-When booted in Windows 7 did it install a driver? (N/A)
18-Is the G2 drive bricked or working fine? (BRICKED)
My Intel SSD is Rocked !!!!! Boot hung at startup after flashing. Unplugged the drive and I was able to get to the BIOS to set back to AHCI. No response from drive after trying it in several machines and countless bios settings. It's really, most sincerely, dead.
BTW I flashed 3 OCZ Vertexes without a hitch. Maybe the bunny suit boys can take some tips from the little guys.
10-31-2009 06:41 AM
2-What g2 size 80 or 160g? (80)
3-Is the drive partitioned? (NO)
4-other harddrives installed? (YES)
5-What version of 7, x86, x64? (using x64)
7-Was it aligned before and after update? (Before)
8-Did you reformat or leave windows on before update?(INSTALLED)
9-Was Intel optimizer installed before or after update? (AFTER)
10-If optimizer was Installed BEFORE the update did you run it?N/A
12-Setting during update? (AHCI)
13-Setting after update? (ACHI)
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? (N/A)
17-When booted in Windows 7 did it install a driver? (YES)
18-Is the G2 drive bricked or working fine? (GOOD)
Asus Rampage II Extreme
Intel Core i7 920
6GB DDR3 Corsair
2x Intel SSD G2(80GB)
1x WD 2TB
Windows 7 x64
10-31-2009 07:41 AM
1-Bios updated to Latest? (YES or NO) YES
2-What g2 size 80 or 160g? (80 or 160) 80
3-Is the drive partitioned? (YES or NO) YES
4-other harddrives installed? (YES or NO) YES
5-What version of 7, x86, x64? (using or will be using) x64
6-Was windows 7 Installed already or was it clean? (INSTALLED or CLEAN) CLEAN
7-Was it aligned before and after update? YES
8-Did you reformat or leave windows on before update?(INSTALLED or ERASED or BRAND NEW) BRAND NEW
9-Was Intel optimizer installed before or after update? (BEFORE or AFTER) AFTER
10-If optimizer was Installed BEFORE the update did you run it? (YES or NO)
11-Bios and windows setting before update? (IDE, AHCI, RAID, etc) -list both if applicable AHCI
12-Setting during update? (IDE, AHCI, RAID, etc) IDE
13-Setting after update? (IDE, AHCI, RAID, etc) AHCI
14-Did you run the flasher twice before booting or installing Win7? (1x, 2x, 3x) 1x
15-Was there an error when flashing? (YES or NO) NO
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? (YES or NO) YES AND THEN INSTALLED WIN7
17-When booted in Windows 7 did it install a driver? (YES or NO)
18-Is the G2 drive bricked or working fine? (BAD or GOOD) GOOD
AMD PHENOM 9950
AMD 790GX
BRAND NEW SSD
I have no problems, been running win7 for 2 days (more than 20 reboots)
Smart is ok, and speed is as expected (Write 80 , Read 250)
10-31-2009 11:46 AM
1-Bios updated to Latest? YES
2-What g2 size 80 or 160g? 80
3-Is the drive partitioned? NO
4-other harddrives installed? YES
5-What version of 7, x86, x64? x64
6-Was windows 7 Installed already or was it clean? INSTALLED
8-Did you reformat or leave windows on before update? INSTALLED
9-Was Intel optimizer installed before or after update? AFTER
10-If optimizer was Installed BEFORE the update did you run it? N/A
11-Bios and windows setting before update? AHCI
12-Setting during update? AHCI
13-Setting after update? AHCI
14-Did you run the flasher twice before booting or installing Win7? 1x
15-Was there an error when flashing? NO
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? YES
17-When booted in Windows 7 did it install a driver? YES
18-Is the G2 drive bricked or working fine? GOOD
CPU = Intel Core i7 860 @ stock levels
Mobo = Gigabyte GA-P55-UD4P
RAM = 4GB GSkill 1600mhz RAM
GPU = MSI 8600GTS 256MB
HDD2 = Western Digital 320GB 7200RPM
HDD3 = Western Digital 250GB 7200RPM
HDD4 = Seagate 200GB 7200RPM
10-31-2009 01:20 PM
1-Bios updated to Latest? YES.
2-What g2 size 80 or 160g? 80 GB.
3-Is the drive partitioned? YES, by the 100 MB W7 partition.
4-Other harddrives installed? NO.
5-What version of 7, x86, x64? X64.
6-Was windows 7 Installed already or was it clean? INSTALLED.
7-Was it aligned before and after update? ALIGNED BEFORE AND AFTER (1.048.576 / 105.906.176 bytes).
8-Did you reformat or leave windows on before update? W7 WAS ALREADY INSTALLED AND REMAINED INSTALLED.
9-Was Intel optimizer installed before or after update? AFTER.
10-If optimizer was Installed BEFORE the update did you run it? N/A.
11-Bios and windows setting before update? AHCI.
12-Setting during update? IDE, BECAUSE THE UPDATER DID NOT DETECTE THE DRIVE IN AHCI.
13-Setting after update? AHCI.
14-Did you run the flasher twice before booting or installing Win7? 2x: THE FIRST TO UPDATE, AND THE SECOND TO CONFIRM ALL WAS OK.
15-Was there an error when flashing? NO.
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? YES.
17-When booted in Windows 7 did it install a driver? YES, IT WAS A DRIVER RELATED TO INTEL SSD.
18-Is the G2 drive bricked or working fine? GOOD, AFTER 5 DAYS.
DRIVE: SSDSA2MH080G2C1
BATCH # CNCV98A801
System:
- W7 Home Premium 6.1.7600
- ASUS Rampage II Extreme X58 BIOS 1504
- i7 920 at stock
- 6 GB memory at 1333 MHz
- GTX 295 with 191.07 driver
