02HA Poll.
UPDATE 10-31-09 @3:20p
I=IDE
A=AHCI R=RAID
BRAND NEW
III - GOOD=01 BAD=00 AAA - GOOD=02 BAD=00 AIA - GOOD=02 BAD=00
RIR - GOOD=00 BAD=01
INSTALLED (NO REFORMAT/ERASE)
III - GOOD=03 BAD=00 AAA - GOOD=06 BAD=02 AIA - GOOD=05 BAD=04 RAR - GOOD=02 BAD=00 RIR - GOOD=03 BAD=00
REFORMAT/ERASE
AAA - GOOD=01 BAD=00 AIA - GOOD=01 BAD=00 IIA - GOOD=01 BAD=00
Also reworded some of the questions. PLEASE POST ANSWERS ONLY. Thx
Here' it goes...
53 REPLIES 53
I bought this drive on the same day the 02HA firmware was released, so I flashed it right out of the box.
1-Bios updated to Latest? YES
2-What g2 size 80 or 160g? 160
3-Is the drive partitioned? NO. Initialized, not partitioned.
4-other harddrives installed? NO.
5-What version of 7, x86, x64? No OS installed at the time of flashing. Installed Win7 x64 afterwards.
6-Was windows 7 Installed already or was it clean? Clean
7-Was it aligned before and after update? What's aligned?
8-Did you reformat or leave windows on before update? n/a
9-Was Intel optimizer installed before or after update? NO, neither.
10-If optimizer was Installed BEFORE the update did you run it? NO
11-Bios and windows setting before update? (IDE, AHCI, RAID, etc) -AHCI
12-Setting during update? AHCI
13-Setting after update? AHCI
14-Did you run the flasher twice before booting or installing Win7? 1x
15-Was there an error when flashing? NO
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? N/A
17-When booted in Windows 7 did it install a driver? N/A
18-Is the G2 drive bricked or working fine? Tested fine.
List your system specs too.
Fujitsu T5010 Tablet PC
Core 2 Duo T9400
4GB DDR3
Intel G45M
BIOS 1.06
That's a lot of weird questions, half of them I don't know how to answer.
1-Bios updated to Latest? (YES)
2-What g2 size 80 or 160g? (80G)
3-Is the drive partitioned? (YES)
4-other harddrives installed? (YES)
5-What version of 7, x86, x64? (x64)
6-Was windows 7 Installed already or was it clean? (INSTALLED)
7-Was it aligned before and after update? (BOTH)
8-Did you reformat or leave windows on before update?(LEFT OS IN PLACE)
9-Was Intel optimizer installed before or after update? (AFTER)
10-If optimizer was Installed BEFORE the update did you run it? (N/A)
11-Bios and windows setting before update? (RAID)
12-Setting during update? (IDE)
13-Setting after update? (RAID)
14-Did you run the flasher twice before booting or installing Win7? (2x, second time to verify update)
15-Was there an error when flashing? (NO)
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? (YES)
17-When booted in Windows 7 did it install a driver? (NO)
18-Is the G2 drive bricked or working fine? (GOOD)
Asus Crossfire III Formula (v1003 BIOS)
AMD SB750 Southbridge (AMD AHCI-compatible RAID Controller Driver 3.1.1540.127)
Phenom II X4 965
8GB DDR3
SSD Pack Date: 09/23/09.
Additional info:
As this is a newly-built system I decided to reinstall using AHCI to gain the benefits of TRIM rather than RAIDing two ageing 200GB consumer drives. Clean install of Win7 x64 (SSD wiped prior), drive partitioned during installation, standard Microsoft AHCI storage drivers used. BIOS configured to use AHCI mode. No problems noticed after more than 24hrs and several dozen reboots.
1-Bios updated to latest? (YES)
2-What G2 size? (80)
3-Is the drive partitioned? (NO)
4-Other hard drives installed? (YES)
5-What version of 7? (x64)
6-Was windows installed already or was it clean? (INSTALLED)
7-Was it aligned before and after update? (YES)
8-Did you reformat or leave windows on before update? (ERASED)
9-Was Intel Optimizer installed before or after update? (AFTER)
10-If Optimizer was installed BEFORE the update did you run it? (N/A)
11-Bios and windows setting before update? (IDE)
13-Setting after update? (AHCI)
14-Did you run the flasher twice before booting or installing win 7? (2x)
15-Was there an error when flashing? (YES)
16-After it flashed and the computer started,did you immediately change the set windows? (NO)
17-When booted in windows 7 did it install a driver? (YES)
Asus Rampage Extreme II
Intel i7 920
6gb OCZ ram
ATI Radeon 4870
SSD pack date 24 Jun 09
1-Bios updated to Latest? YES (Latest brings only support for new CPUs)
1-What g2 size 80 or 160g? 160
2-Is the drive partitioned? YES (Win7 100MB system partition is the second partition)
3-other harddrives installed? NO
3-Was windows 7 Installed already or was it clean? CLEAN
4-What version of 7, x86, x64? x64
5-Was it aligned before and after update? Dont know
6-Did you reformat or leave windows on before update? CLEAN INSTALL OF WIN7
7-Was Intel optimizer installed before or after update? BEFORE
8-If optimizer was Installed before the update did you run it? YES - IT DIDN'T DO ANYTHING, WRONG FIRMWARE VERSION MSG
9-Bios and windows setting before update? BIOS: AHCI Windows: AHCI
10-Setting during update? IDE (I accidentally forgot to turn off the HD password and had to go back into BIOS)
11-Setting after update? AHCI
12-Did you run the flasher twice before booting or installing Win7? YES, 2x
13-Was there an error when flashing? NO
14-After it flashed and the computer started, did you immediately change the settings back to what it was before booting into windows? YES
15-When booted in Windows 7 did it install a driver? YES
16-Is the G2 drive bricked or working fine? WORKING FINE...
PC spec:
Thinkpad T61
6GB DDR2
NVIDIA
Intel X25-M G2 160gb (system)
Windows 7 Ultimate 64bit (MSDN)
Also have a client who did the update on a ThinkPad W500 without any issues.... I stopped him from doing another laptop until more info comes out.
Probably those with BRICKED drives should also post their mainboard and the chipset (especially the southbridge chip) - you should find that info in your mainboard manual and/or on the manufacturer's website.
