02HA Poll.
UPDATE 10-31-09 @3:20p
I=IDE
A=AHCI R=RAID
BRAND NEW
III - GOOD=01 BAD=00 AAA - GOOD=02 BAD=00 AIA - GOOD=02 BAD=00
RIR - GOOD=00 BAD=01
INSTALLED (NO REFORMAT/ERASE)
III - GOOD=03 BAD=00 AAA - GOOD=06 BAD=02 AIA - GOOD=05 BAD=04 RAR - GOOD=02 BAD=00 RIR - GOOD=03 BAD=00
REFORMAT/ERASE
AAA - GOOD=01 BAD=00 AIA - GOOD=01 BAD=00 IIA - GOOD=01 BAD=00
Also reworded some of the questions. PLEASE POST ANSWERS ONLY. Thx
Here' it goes...
53 REPLIES 53
1-Bios updated to Latest? = Yes
2-What g2 size 80 or 160g? = 160 3-Is the drive partitioned? = YES 60/100 (approx) 4-other harddrives installed? = NO 5-What version of 7, x86, x64? = Win 7 X64 6-Was windows 7 Installed already or was it clean? = It was a new and unused G2 drive. 7-Was it aligned before and after update? = N/A - Brand new G2 drive 8-Did you reformat or leave windows on before update? = N/A - Brand new G2 drive 9-Was Intel optimizer installed before or after update? = N/A - Brand new G2 drive 10-If optimizer was Installed BEFORE the update did you run it? = N/A - Brand new G2 drive 11-Bios and windows setting before update? (IDE, AHCI, RAID, etc) = Laptop only has two BIOS options (SATA / AHCI) - I kept the default AHCI setting. 12-Setting during update? (IDE, AHCI, RAID, etc) = AHCI 13-Setting after update? (IDE, AHCI, RAID, etc) = AHCI<span style="font-family: "Times New Roman","serif"; ...
1-Bios updated to Latest? YES
2-What g2 size 80 or 160g? 80G
3-Is the drive partitioned? YES
4-other harddrives installed? NO
5-What version of 7, x86, x64? Gentoo Linux 2.6.31-gentoo-r4 # 1 SMP PREEMPT
6-Was windows 7 Installed already or was it clean? Gentoo Linux 2.6.31-gentoo-r4 INSTALLED
7-Was it aligned before and after update? what do you mean by "aligned"?
8-Did you reformat or leave windows on before update? fresh install
9-Was Intel optimizer installed before or after update? NO, using linux
10-If optimizer was Installed BEFORE the update did you run it? NO, using linux
11-Bios and windows setting before update? AHCI / libata/ahci compiled into kernel
12-Setting during update? SATA
13-Setting after update? AHCI
14-Did you run the flasher twice before booting or installing Win7? 2x
15-Was there an error when flashing? NO
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? YES
17-When booted in Windows 7 did it install a driver? NO, using Linux
18-Is the G2 drive bricked or working fine? BAD
hw specs:
- asus AT3N7A-I
- Corsair XMS2 DHX Series DIMM Kit 4GB PC2-6400U CL4-4-4-12
- LG GH-22NS
sw specs:
- Linux 2.6.31-gentoo-r4 # 1 SMP PREEMPT i686 Intel(R) Atom(TM) CPU 230 @ 1.60GHz GenuineIntel GNU/Linux
- grub kernel parameter: elevator=noop
- mounting with noatime
partitions:
sda1 -> ext2 (primary)
sda2 -> swap (primary)
sda3 -> ext4 (primary)
sda4 -> ext4 (primary)
notes:
after the fw update i was able to boot normally. but after about 10min. the system didn't respond anymore, altough webservices were still available. i had to do a hard reset. afterwards i recognized the smart error reported by the bios. nevertheless i tried to boot the system. mbr was accessed and grub was trying to access the kernel. so i was able to see the fbsplash but nothing more and a msgs that states the kernel would boot. so obviously the boot partition (ext2) was accessed succesfully, but not / (ext4). after rebooting with a livecd i tried to mount the drive manually. that didn't work, also when specifying the filesystem type. i only got a error message about a wrong superblock etc. so i tried to check partitions with cfdisk. while cfdisk tries to access the drive it puts out a lot of i/o error msgs, but showing the partition table finally. the overview couldn't recognize the fs types of the former ext4 partitions but only the ext2 partition. -> end of the story.
1-Bios updated to Latest? NO, approximately 3-year old BIOS
2-What g2 size 80 or 160g? Two 80 GB drives, ICH8 RAID 0 array (128K stripe)
3-Is the drive partitioned? NO
4-other harddrives installed? YES, 4 rotational SATA drives
5-What version of 7, x86, x64? Win 7 Professional x64 RTM
6-Was windows 7 Installed already or was it clean? INSTALLED
7-Was it aligned before and after update? YES
8-Did you reformat or leave windows on before update? INSTALLED
9-Was Intel optimizer installed before or after update? AFTER
10-If optimizer was Installed BEFORE the update did you run it? N/A
11-Bios and windows setting before update? BIOS = RAID, Windows = Intel MSM RAID
12-Setting during update? IDE
13-Setting after update? RAID
14-Did you run the flasher twice before booting or installing Win7? 1x (flashed both drives)
18-Is the G2 drive bricked or working fine? Both drives are GOOD
List your system specs too.
Asus P5B Deluxe, BIOS 0910
4 GB memory
Core 2 Duo E6400
I Believe the SDD has Manufacturing date can post it too. Pack dates = 8/15/09 and 9/12/09
1-Bios updated to Latest? (YES)
2-What g2 size 80 or 160g? (160)
3-Is the drive partitioned? (NO)
4-other harddrives installed? (YES)
5-What version of 7, x86, x64? (x64)
6-Was windows 7 Installed already or was it clean? (ALREADY INSTALLED)
7-Was it aligned before and after update? (YES)
8-Did you reformat or leave windows on before update?(LEFT WINDOWS INSTALLED AS-IS)
9-Was Intel optimizer installed before or after update? (AFTER)
10-If optimizer was Installed BEFORE the update did you run it? (N/A)
11-Bios and windows setting before update? (AHCI)
12-Setting during update? (AHCI -- BUT DIDN'T WORK, AND ONLY OTHER OPTIONS IS RAID ... HAD TO TAKE DRIVE TO ANOTHER COMPUTER WITH IDE)
13-Setting after update? (AHCI)
14-Did you run the flasher twice before booting or installing Win7? (2x, but 1st couldn't find drive, 2nd was on other computer where it took)
15-Was there an error when flashing? (NO (SEE ABOVE--SIMPLY COULDN'T FIND DRIVE ON 1ST COMPUTER)
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? (N/A)
17-When booted in Windows 7 did it install a driver? (YES, APPARENTLY -- IT SAID IT NEEDED TO RESTART)
18-Is the G2 drive bricked or working fine? (GOOD SO FAR)
Intel i7 920 (Dell XPS-435T, BIOS A13)
6GB RAM
Intel X-25M 160GB & WD Black Caviars
2-What g2 size 80 or 160g? 160
5-What version of 7? Win 7 x64 RC build 7100
6-Was windows 7 Installed already or was it clean? Already installed
7-Was it aligned before and after update? After: yes Before: don't know, but I assume yes.
8-Did you reformat or leave windows on before update? Left windows on
9-Was Intel optimizer installed before or after update? After
10-If optimizer was Installed BEFORE the update did you run it? n/a
11-Bios and windows setting before update? Mac Pro - Can't change it
12-Setting during update? Don't know - Mac Pro
13-Setting after update? Don't know - Mac Pro
15-Was there an error when flashing? No
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? NO
17-When booted in Windows 7 did it install a driver? YES
18-Is the G2 drive bricked or working fine? GOOD
Mac Pro (Early 2008)
Windows 7 RC build 7100 in boot camp, using Snow Leopard's bootcamp drivers
