02HA Poll.
UPDATE 10-31-09 @3:20p
I=IDE
A=AHCI R=RAID
BRAND NEW
III - GOOD=01 BAD=00 AAA - GOOD=02 BAD=00 AIA - GOOD=02 BAD=00
RIR - GOOD=00 BAD=01
INSTALLED (NO REFORMAT/ERASE)
III - GOOD=03 BAD=00 AAA - GOOD=06 BAD=02 AIA - GOOD=05 BAD=04 RAR - GOOD=02 BAD=00 RIR - GOOD=03 BAD=00
REFORMAT/ERASE
AAA - GOOD=01 BAD=00 AIA - GOOD=01 BAD=00 IIA - GOOD=01 BAD=00
Also reworded some of the questions. PLEASE POST ANSWERS ONLY. Thx
Here' it goes...
53 REPLIES 53
1-Bios updated to Latest? (YES or NO) YES
2-What g2 size 80 or 160g? (80 or 160) 80
3-Is the drive partitioned? (YES or NO) YES (Win7 configured it as part of initial on a clean disk)
4-other harddrives installed? (YES or NO) YES (2xWD 1TB in RAID1 as data drives)
5-What version of 7, x86, x64? (using or will be using) Win7 Home x64 RETAIL
6-Was windows 7 Installed already or was it clean? (INSTALLED or CLEAN) Clean: fresh install
7-Was it aligned before and after update? N/A
8-Did you reformat or leave windows on before update?(INSTALLED or ERASED or BRAND NEW) BRAND NEW
9-Was Intel optimizer installed before or after update? (BEFORE or AFTER) BEFORE
10-If optimizer was Installed BEFORE the update did you run it? (YES or NO) YES (and it stated that the drive FW needed updating, but displayed drive data like SMART, etc.)
11-Bios and windows setting before update? (IDE, AHCI, RAID, etc) -list both if applicable RAID
12-Setting during update? (IDE, AHCI, RAID, etc) IDE
13-Setting after update? (IDE, AHCI, RAID, etc) RAID
14-Did you run the flasher twice before booting or installing Win7? (1x, 2x, 3x) 1x
15-Was there an error when flashing? (YES or NO) No
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? (YES or NO) Yes
17-When booted in Windows 7 did it install a driver? (YES or NO) Yes
18-Is the G2 drive bricked or working fine? (BAD or GOOD) BAD
System specs:
DFI LP UT X58-T3eH8 w/ D619 FW
Core i7 920 w/ Zalmon 9000 (not O/C)
3x2GB OCZ 10666
1xIntel 80GB G2 SSD (boot)
2xWD 1TB RAID1 (data)
Sapphire Radeon 5870
Antec 850W Signature PSU
Antec P182 case
1-Bios updated to Latest? YES
2-What g2 size 80 or 160g? 160
3-Is the drive partitioned? YES
4-other harddrives installed? YES
5-What version of 7, x86, x64? x64
6-Was windows 7 Installed already or was it clean? INSTALLED
7-Was it aligned before and after update? YES
8-Did you reformat or leave windows on before update? INSTALLED
9-Was Intel optimizer installed before or after update? wanted to install it AFTERwards
10-If optimizer was Installed BEFORE the update did you run it? -
11-Bios and windows setting before update? AHCI
12-Setting during update? IDE Native Mode
13-Setting after update? AHCI
14-Did you run the flasher twice before booting or installing Win7? 1x
15-Was there an error when flashing? NO BUT DRIVE IS DEAD SINCE REBOOT
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? YES
17-When booted in Windows 7 did it install a driver? BOOTING SLOWED DOWN WITH SDD CONNECTED, BIOS CAN'T FIND SSD ANY MORE
18-Is the G2 drive bricked or working fine? BAD
GIGABYTE P35-DS4 2.1 with latest firmware
Intel Core2Quad Q6600 @ 3.00 GHz
2x 2 GB OCZ Platinum DDR2-1066 5-5-5-15
ATI Radeon 4870 512MB
1x Intel X25-M G2 Postville 160GB
1x Seagate Barracuda 7200.11 1500GB (ST31500341AS)
SSD is dead after flashing, see /thread/7737?tstart=0 my thread for details.
2-What g2 size 80 or 160g? 80
5-What version of 7. x64 Ultimate RTM from Technet
7-Was it aligned before and after update? Yes
9-Was Intel optimizer installed before or after update? BEFORE
10-If optimizer was Installed BEFORE the update did you run it? NO
12-Setting during update? AHCI
14-Did you run the flasher twice before booting or installing Win7? 1x only
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? N/A - no settings changed
17-When booted in Windows 7 did it install a driver? YES - and rebooted after that fine
18-Is the G2 drive bricked or working fine? GOOD
List your system specs too.
Abit IP35-Pro Motherboard
Jmicron controller disabled (always has been since I dont use it)
Drive on port 2 of ICH9R contoller
SATA DVD-RW on port 1, 640GB WD SATA on port 0. BIOS is set to boot from CD first, then SSD.
SDD manufacturing date. I'll check this when I get home this evening and update this post.
1-Bios updated to Latest? YES (Ver 1A)
1-What g2 size 80 or 160g? 80
2-Is the drive partitioned? YES (100MB system partition is the first partition - its always been like that out of the box)
3-other harddrives installed? YES
3-Was windows 7 Installed already or was it clean? INSTALLED
4-What version of 7, x86, x64? x64
5-Was it aligned before and after update? Don't know
6-Did you reformat or leave windows on before update? INSTALLED - then had to reformat
7-Was Intel optimizer installed before or after update? Neither
8-If optimizer was Installed before the update did you run it? N/A
9-Bios and windows setting before update? BIOS: AHCI Windows: AHCI
10-Setting during update? IDE (fw update wouldn't see SSD unless set to this)
11-Setting after update? AHCI
12-Did you run the flasher twice before booting or installing Win7? Only once
13-Was there an error when flashing? NO - But it didnt return a successfull update and just hung - so had to reboot
14-After it flashed and the computer started, did you immediately change the settings back to what it was before booting into windows? YES
15-When booted in Windows 7 did it install a driver? YES - Then crashed, After another reboot explorer kept crashing.
16-Is the G2 drive bricked or working fine? Working fine - but wierd stat results in Windows7
PC spec:
MSI P35 Neo2 / Q6600
4GB DDR2 800Mhz
GeForce 8800GT
SB X-Fi Fatal1ty
Sony DVD-RW SATA 1
Intel X25-M G2 80gb SATA 0
1 x 500Gb SATA Seagate 7200.9 SATA 2
1 x 300Gb SATA Seagate 7200.8 SATA 3
Windows 7 Ultimate 64bit (RTM) / Standard Windows SATA/HDD drivers.
1-Bios updated to Latest? (YES)
2-What g2 size 80 or 160g? (160)
3-Is the drive partitioned? (NO)
4-other harddrives installed? (NO)
5-What version of 7 (x64)
6-Was windows 7 Installed already or was it clean? (INSTALLED)
7-Was it aligned before and after update? (DON'T KNOW)
8-Did you reformat or leave windows on before update?(INSTALLED)
9-Was Intel optimizer installed before or after update? (AFTER)
11-Bios and windows setting before update? (AHCI)
12-Setting during update? (AHCI)
13-Setting after update? (AHCI)
14-Did you run the flasher twice before booting or installing Win7? (1x)
15-Was there an error when flashing? (NO)
17-When booted in Windows 7 did it install a driver? (NO)
18-Is the G2 drive bricked or working fine? (BAD)
ACER 6935G
