02HA Poll.
10-28-2009 08:25 PM
UPDATE 10-31-09 @3:20p
I=IDE
A=AHCI R=RAIDBRAND NEW
III - GOOD=01 BAD=00 AAA - GOOD=02 BAD=00 AIA - GOOD=02 BAD=00RIR - GOOD=00 BAD=01
INSTALLED (NO REFORMAT/ERASE)
III - GOOD=03 BAD=00 AAA - GOOD=06 BAD=02 AIA - GOOD=05 BAD=04 RAR - GOOD=02 BAD=00 RIR - GOOD=03 BAD=00REFORMAT/ERASE
AAA - GOOD=01 BAD=00 AIA - GOOD=01 BAD=00 IIA - GOOD=01 BAD=00Also reworded some of the questions. PLEASE POST ANSWERS ONLY. Thx
Here' it goes...
10-28-2009 10:08 PM
1-Bios updated to Latest? YES
2-What g2 size 80 or 160g? 80
3-Is the drive partitioned? YES
4-other harddrives installed? NO
5-What version of 7, x86, x64? 7 x86
6-Was windows 7 Installed already or was it clean? INSTALLED
7-Was it aligned before and after update? BEFORE
8-Did you reformat or leave windows on before update? INSTALLED
9-Was Intel optimizer installed before or after update? AFTER
10-If optimizer was Installed BEFORE the update did you run it? N/A
11-Bios and windows setting before update? AHCI
12-Setting during update? AHCI
13-Setting after update? AHCI
14-Did you run the flasher twice before booting or installing Win7? 1x
15-Was there an error when flashing? NO
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? N/A-NEVER CHANGED ANYTHING
17-When booted in Windows 7 did it install a driver? YES
18-Is the G2 drive bricked or working fine? GOOD
System is Dell XPS M1330, 2.2GHz T7500, ICH8M, 4GB, GeForce 8400M GS
10-28-2009 11:34 PM
4-other harddrives installed? YES
5-What version of 7, x86, x64? Windows 7 Professional x64
7-Was it aligned before and after update? BEFORE, I think windows 7 does this automatically when it was installed.
9-Was Intel optimizer installed before or after update? BEFORE
10-If optimizer was Installed BEFORE the update did you run it? YES, but trim was not possible (of course), because fw was not installed yet
14-Did you run the flasher twice before booting or installing Win7? TWICE
18-Is the G2 drive bricked or working fine? WORKING FINE
System is homebuilt asus p5b-deluxe wifi, 8800gt, q9300, 3gb RAM, SSD:X25M-G2 80Gb, HDDs: 1,5Tb seagate, 750gb Samsung
10-29-2009 01:40 AM
Hope this thread helps them (I think its a very good idea! )
1-Bios updated to Latest? - YES
2-What g2 size 80 or 160g? - 80
3-Is the drive partitioned? - NO (no additional partitions, just the primary one)
4-other harddrives installed? - YES
5-What version of 7, x86, x64? Vista x64
6-Was windows 7 Installed already or was it clean? Visa-Installed
7-Was it aligned before and after update? - Yes
8-Did you reformat or leave windows on before update? - INSTALLED
9-Was Intel optimizer installed before or after update? - AFTER
10-If optimizer was Installed BEFORE the update did you run it? -
11-Bios and windows setting before update? (IDE, AHCI, RAID, etc) - IDE
12-Setting during update? (IDE, AHCI, RAID, etc) - IDE
13-Setting after update? (IDE, AHCI, RAID, etc) - IDE
14-Did you run the flasher twice before booting or installing Win7? - 1x
15-Was there an error when flashing? - YES, read error on drive a:, did a retry, then a ignore. Reported flash was succesful.
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? - NO, did not change settings
17-When booted in Windows 7 did it install a driver? - Vista, YES
System:
Asus P6T SE
Intel Core i7 920 @ 3.2 MHz
Asus GTX275
Intel Postville G2 80GB + Samsung Spinpoint F3 1TB
6GB Kingston 1600 memory
10-29-2009 01:50 AM
5-What version of 7, x86, x64? Windows 7 x64
7-Was it aligned before and after update? I think so.
10-If optimizer was Installed BEFORE the update did you run it? NO
12-Setting during update? IDE
14-Did you run the flasher twice before booting or installing Win7? NO
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? YES
17-When booted in Windows 7 did it install a driver? YES (SSD)
Hardware:
Acer Aspire 8930G
4GB RAM
add. Samsung 2,5" 500GB HDD
10-29-2009 02:25 AM
2-What g2 size 80 or 160g? 160
3-Is the drive partitioned? only other partition is the 100MB startup partion that Windows 7 creates upon installation
5-What version of 7, x86, x64? Windows 7 Enterprise x64 RTM from MSDN (it's activated)
7-Was it aligned before and after update? YES / YES
10-If optimizer was Installed BEFORE the update did you run it? YES (only reported that the drive firmware needed an upgrade for it to function)
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? N/A (no change)
17-When booted in Windows 7 did it install a driver? YES (it installed something that required a restart, not sure it was a driver though)
19-TRIM support? ACTIVE
20-Encryption? YES (the drive is Bitlocker encrypted and was so even before the firmware upgrade)
Lenovo ThinkPad T61 with 4GB RAM
