10-28-2009 08:25 PM
UPDATE 10-31-09 @3:20p
I=IDE
A=AHCI R=RAIDBRAND NEW
III - GOOD=01 BAD=00 AAA - GOOD=02 BAD=00 AIA - GOOD=02 BAD=00RIR - GOOD=00 BAD=01
INSTALLED (NO REFORMAT/ERASE)
III - GOOD=03 BAD=00 AAA - GOOD=06 BAD=02 AIA - GOOD=05 BAD=04 RAR - GOOD=02 BAD=00 RIR - GOOD=03 BAD=00REFORMAT/ERASE
AAA - GOOD=01 BAD=00 AIA - GOOD=01 BAD=00 IIA - GOOD=01 BAD=00Also reworded some of the questions. PLEASE POST ANSWERS ONLY. Thx
Here' it goes...
11-03-2009 07:22 AM
Running Gigabyte EX58-UD3R board with Core i7 920. Manufacturing date was July/August I beleive.
11-03-2009 11:55 PM
1-Bios updated to Latest? YES
4-Is the drive partitioned? (YES or NO) NO
5-other harddrives installed? (YES or NO) NO
6-Was drive aligned BEFORE and AFTER update? ?!?
7-OS that you have installed or will be installing? Win7 Enterprise
8-If using windows and already installed, what driver is being used before updating firmware? (Intel or MS, AHCI, IDE) Intel AHCI
9-Bios setting before update? (IDE, AHCI, RAID, etc) AHCI
during update? (IDE, AHCI, RAID, etc) AHCI
after update? (IDE, AHCI, RAID, etc) AHCI
10-Did you run the flasher via USB or CD? CD
11-How many times did you run the flasher? (1x, 2x, 3x) 1
12-Was there an error when flashing? (YES or NO) NO
13-After it flashed and the computer rebooted, did you immediately change the settings back to what it was before booting/installing OS? (YES or NO) Changed nothing
14-When booted in Windows did it install a driver? (YES or NO) if applicable Dont know
16-If possible, what driver is being used in Windows after firmware? (Intel or MS, AHCI, IDE) INTEL AHCI
17-Is the G2 drive bad or working fine? (BAD or GOOD) GOOD
Cheers,
Odin4242
11-04-2009 03:11 AM
1-YES
2-80
3-INSTALLED
4-YES
5-YES
6-BEFORE
7-XP-EN 32 bit
8-AHCI
9-Before: AHCI during: AHCI after: AHCI
10-CD
11-1x
12-NO
13-NO
14-NO
15-none
16-AHCI
17-GOOD
Running the new FW for a week now with no issues. Also, the Toolkit is working without issues.
11-07-2009 09:23 AM
1-Bios updated to Latest? (YES)
2-What g2 size 80 or 160g? (80)
3-Was drive BRAND NEW / ERASED (hdd erase/reformat)/ INSTALLED (OS already installed) before update? INSTALLED
4-Is the drive partitioned? (YES - windows 7 200 MB recovery partition)
5-other harddrives installed? (YES - 2 x 1 TB HDD in RAID 1)
6-Was drive aligned BEFORE and AFTER update? Watchu talkin bout Willis?
7-OS that you have installed or will be installing? Win 7 x64
8-If using windows and already installed, what driver is being used before updating firmware? (IMSM 8.8 - RAID)
9-Bios setting before update? (RAID)
during update? (IDE)
after update? (RAID)
11-How many times did you run the flasher? (1x)
12-Was there an error when flashing? (NO)
13-After it flashed and the computer rebooted, did you immediately change the settings back to what it was before booting/installing OS? (YES)
14-When booted in Windows did it install a driver? (YES - 3 drivers)
Driver Management concluded the process to install driver FileRepository\disk.inf_amd64_neutral_10ce25bbc5a9cc43\disk.inf for Device Instance ID IDE\DISKINTEL_SSDSA2M080G2GC____________________2CV102HA\4&19FEAA6C&0&0.1.0 with the following status: 0x0.
Driver Management concluded the process to install driver FileRepository\volume.inf_amd64_neutral_1b1a512d99c5b72c\volume.inf for Device Instance ID STORAGE\VOLUME\{D0A233F2-C29B-11DE-B220-806E6F6E6963}# 0000000006500000 with the following status: 0x0.
Driver Management concluded the process to install driver FileRepository\volume.inf_amd64_neutral_1b1a512d99c5b72c\volume.inf for Device Instance ID STORAGE\VOLUME\{D0A233F2-C29B-11DE-B220-806E6F6E6963}# 0000000000100000 with the following status: 0x0.
16-If possible, what driver is being used in Windows after firmware? (IMSM 8.8 - RAID unless superceded by those listed above)
17-Is the G2 drive bad or working fine? (GREAT)
ASUS P6T Deluxe V2
Intel Core i7 920 @ 2.67
Corsair 6 GB DDR3 1600 (7-7-7-20)
Corsair HX850 PSU
XFX Radeon 5870
Intel 80 GB SSD Gen2
2 x WD Black 1 TB in RAID 1
