02HA Poll.
10-28-2009 08:25 PM
UPDATE 10-31-09 @3:20p
I=IDE
A=AHCI R=RAIDBRAND NEW
III - GOOD=01 BAD=00 AAA - GOOD=02 BAD=00 AIA - GOOD=02 BAD=00RIR - GOOD=00 BAD=01
INSTALLED (NO REFORMAT/ERASE)
III - GOOD=03 BAD=00 AAA - GOOD=06 BAD=02 AIA - GOOD=05 BAD=04 RAR - GOOD=02 BAD=00 RIR - GOOD=03 BAD=00REFORMAT/ERASE
AAA - GOOD=01 BAD=00 AIA - GOOD=01 BAD=00 IIA - GOOD=01 BAD=00Also reworded some of the questions. PLEASE POST ANSWERS ONLY. Thx
Here' it goes...
10-28-2009 08:37 PM
1-Bios updated to Latest? YES
1-What g2 size 80 or 160g? 160
2-Is the drive partitioned? NO
3-other harddrives installed? NO
3-Was windows 7 Installed already or was it clean? CLEAN
4-What version of 7, x86, x64? CLEAN
5-Was it aligned before and after update? not sure, was BRAND NEW
6-Did you reformat or leave windows on before update? BRAND NEW
7-Was Intel optimizer installed before or after update? NEITHER, WIN 7
8-If optimizer was Installed before the update did you run it? N/A
9-Bios and windows setting before update? (IDE, AHCI, RAID, etc) not sure, default setting, no RAID
10-Setting during update? (IDE, AHCI, RAID, etc) not sure, default setting, no RAID
11-Setting after update? (IDE, AHCI, RAID, etc) not sure, default setting, no RAID
12-Did you run the flasher twice before booting or installing Win7? 1x
13-Was there an error when flashing? NO
14-After it flashed and the computer started, did you immediately change the settings back to what it was before booting into windows? NEW INSTALL
15-When booted in Windows 7 did it install a driver? NEW INSTALL
16-Is the G2 drive bricked or working fine? GOOD
ThinkPad X61 Tablet.
10-28-2009 08:51 PM
1-What g2 size 80 or 160g? 80
3-other harddrives installed? YES
3-Was windows 7 Installed already or was it clean? INSTALLED
4-What version of 7, x86, x64? x64
5-Was it aligned before and after update? Dont know...how do I tell?
6-Did you reformat or leave windows on before update? Is this the same as # 3? Installed before update
7-Was Intel optimizer installed before or after update? AFTER
8-If optimizer was Installed before the update did you run it? YES
9-Bios and windows setting before update? IDE - My Bios doesn't have any options (Gateway)
10-Setting during update? IDE
11-Setting after update? IDE
12-Did you run the flasher twice before booting or installing Win7? 2x per the instructions
14-After it flashed and the computer started, did you immediately change the settings back to what it was before booting into windows? No change
15-When booted in Windows 7 did it install a driver? I dont think so. It rebooted but I dont think there was a new driver installed. There is no option to rollback the driver.
10-28-2009 09:34 PM
2-Is the drive partitioned? No
5-Was it aligned before and after update? I assume so
6-Did you reformat or leave windows on before update?INSTALLED
9-Bios and windows setting before update? RAID (only sey for HD RAID arrays)
10-Setting during update? AHCI (fw update wouldn't see SSD unless set to this)
11-Setting after update? RAID
12-Did you run the flasher twice before booting or installing Win7? 2x (second time to check fw had taken)
14-After it flashed and the computer started, did you immediately change the settings back to what it was before booting into windows? YES
15-When booted in Windows 7 did it install a driver? YES
PC spec:
Asus P6T Deluxe v1
i7 920
6gb
nVidia GTX 285
Intel G2 160gb (system)
3x WD 1TB hard disks in RAID 5
2x Segate 320GB hard disks in RAID1
10-28-2009 09:50 PM
1-Bios updated to Latest? NO (Latest brings only support for new CPUs)
2-Is the drive partitioned? YES (Win7 100MB system partition is the second partition)
6-Did you reformat or leave windows on before update? INSTALLED
7-Was Intel optimizer installed before or after update? AFTER (on the first bootup)
9-Bios and windows setting before update? BIOS: AHCI Windows: AHCI
10-Setting during update? IDE (fw update wouldn't see SSD unless set to this)
11-Setting after update? AHCI
16-Is the G2 drive bricked or working fine? BRICKED!
PC spec:
Asus P5B
Q6600
4GB DDR2
ATI HD5850
SB X-Fi Xtreme Gamer
Intel X25-M G2 80gb (system)
3 other SATA hard disks
1 other PATA hard disk
Windows 7 Ultimate 64bit (MSDN)
